what do people recommend for bearing upgrades? I want to replace the bearings in the transmission and the knuckles, and I am wondering if there is a kit I should consider.
I'm waiting for my G2 chassis before installing my UE servo saver:cool: so those bearings are covered as are my diffs with the Spyder 6s:D from Robin.
looks like I won't be buying the kits. :eek: I'll have to look to see which ones I really need. I'm sure Mike would rather have my money. ;)
The Boca comment on the Ultra bearings for electric, I suppose that means it'll hold up to BL as well? Any differences between the rubber seal 3racing and the Boca that should be noted?
I do notice good bearing's are a must, my racerx 16mm bearing's(ue) allready have allot of slop and need to be changed soon. Not even 15 run's on them.
It is quite expensive, but then again, bearing's are needed to transform the power(well duh). Don't save money on this part.
