Originally Posted by Promod
Blew the dust off my old eagle tree data. I have 4 different motors that were tested on 12 cells. A Hacker 7XL, Hacker 9L,basic 4200 and XL3100. All pulled over 1000 watts with the XL3100 being the highest at 1200 watts. But the Hacker 7XL was the fastest in the truck. Ran 4 or 5 different dual motor setups but can't find any data on them.
At least for me larger motors always seemed to run higher top speeds. They seemed to be able to pull a much higher gear compared to a smaller motor.
Promod
The wattages for the motors you tested would be completely differnt on lipos i bet. If two 6xls are used and the amount of batteries required, you may end up with more than a 10 lb setup.
