jhautz
jhautz's Avatar
02.06.2008, 10:35 AM
The best way I have found to get the nut off is a deep socket wrench that fits the nut. (cant remeber the size off the top of my head) and a crank shaft locking tool for the motor. But if you dont have the crank shaft locking tool then a fly wheel wrench will work and if you dont have the fly wheel wrench then in a pinch big pair of pliers on the flywheel will do the job top get the nut off. I would wrap the flywheel in a rag before using the pliers on it though. just to make sure you dont make to bad of marks in it with the pliers.
to make it...
or break it...
Silent...But Deadly
