02.06.2008, 10:04 PM
cells layed out end to end rather than side-by-side. The connecting conductor between stick pack cells are generally thin foil-like metal tabs. Side by side cells use actual bus bars for better current flow without voltage drop.
Shane_744
02.06.2008, 10:20 PM
Do you have an example or link? I guess you are talking about the "flat" or "side by side" packs (see link below)
Here http://www.maxamps.com/proddetail.ph...68-Pair&cat=78
Thanks
"Anyone interested in grabbin' a couple of burgers and hittin' the cemetery?" Royal Tenenbaum
