MetalMan
MetalMan's Avatar
02.07.2008, 07:22 PM
Adding to what Arct1k said, you do in fact want/need low ESR caps. If the ones you got aren't low ESR, then they won't work well as replacements for the stock caps. In some cases you can tell just by the temperature rating: 105 deg C is often an indicator of the caps being low ESR.
