FLM e-maxx chassis with a carbon addition. :)
Serum
Serum's Avatar
FLM e-maxx chassis with a carbon addition. :) - 02.09.2008, 05:44 PM
Here is the result of a plan i had for quite some time now. Had the drawings for a longer time, but never had a change to have them machined.
Today i jumped the opportunity and took my carbon sheet trough a CNC mill!
In the attached PDF is the plan of this 'conversion'
What i did was cut off the battery 'ears' of the flm chassis with a handsaw, used a wood router and a 45 degree bit to get the chamfered edges. The holes in the braces of the chassis changed from M3 to M4. the end of the lower plate is resting on the rear skid.
my intention was to make a lower CG that was compatible/adjustable with the different sizes of lipo packs.
I like the low CG of the gmaxx chassis, and the bashing thing about the FLM..
Anyway, here are some pics..
Creative.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Creative. - 02.09.2008, 05:51 PM
Hey Serum now that looks like some pretty creative stuff. With your CG that low you should be able to do a high speed setup and have better handling capabilities. So what are your plans for that thing now that you have something a little bit new?
Serum
Serum's Avatar
02.09.2008, 05:55 PM
Planning on putting an actual motor in it and run it on 5S2P..
think I'll put a 1950-8 or a 9 or 10XL in it. she will use the traditional 2 speed transmission.
02.09.2008, 07:36 PM
Awesome work, I like that alot. Looks alot like the one Mike made for someone a while back that had the center diff fitted also, only your CF version is somewhat sexier I reckon. Get some more pictures once its finished, it looks proper-Bo dude!
jhautz
jhautz's Avatar
02.09.2008, 07:52 PM
Very cool Serum. I like it.
What holds the little lipo stops in place?
to make it...
or break it...
Silent...But Deadly
tashpop
02.09.2008, 09:19 PM
man, i've been thinking about doing the same thing with mine. you beat me to it. i'll be sure not to copy your design when i get around to it.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
Serum
Serum's Avatar
02.10.2008, 11:09 AM
4 of the 8 stops are held in place with 2k glue, and the other two (length) can be hold in place by a lexan 1.5 mm thick sheet, that presses the plates in, and lays under the battery to press them tight in place.
it would be an option to make the braces from aluminum and use button head screws to hold them in place.
It would be fair cheap to produce if you have them laser cut.
lutach
lutach's Avatar
05.21.2008, 01:07 PM
I can't believe I didn't post something on this master piece. WOW.
Understand
JERRY2KONE
JERRY2KONE's Avatar
Understand - 05.21.2008, 02:53 PM
Thats ok Lutach we understand since there was nothing in the title saying 'HIGH VOTAGE PROJECT". Tee hee hee. Actually what happened with the project Serum? You haven't posted up any updates in quite a while. Is it up and running yet?
DickyT
05.21.2008, 03:09 PM
I'm with you there. I missed this one completely. Very nice work Serum! That is one of if not the nicest custom maxx I have seen.
That CF sheet is dual layer 4mm?
Serum
Serum's Avatar
05.21.2008, 04:03 PM
I made some more parts for it, (finally got a lathe) I simple need to put a motor in it and get it rolling, but there are quite a few other projects waiting for me..
Thanks for the kind words Guys,
lutach
lutach's Avatar
05.21.2008, 06:36 PM
This is truly unique and it does say HV all over it. Look at the 5S lipos on one side, so you know what that means. Ok, so now I know where you were coming from when you said Mr. C's kit aren't all that.
Edit: I've been in this hobby for a while now and I'm still learning and finding new R/Cs out there that are just awesome.
lutach
lutach's Avatar
05.21.2008, 06:39 PM
This beauty has HV written all over it. Wow, 10S lipos would make it really happy. Serum can run it for Hours.
DickyT
05.21.2008, 09:26 PM
look 2 posts above this one I quoted
highflier
Emaxx- FLM wannabe
05.22.2008, 09:05 PM
So where does one buy sheets of Carbon Fiber?
Highflier
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
