Backfire
02.10.2008, 09:11 PM
I recently purchased a 125b for my XB8 and XT8 conversions. It was much smoother than the MM I tested, but that was before the latest MM firmware update. This was expected as I am using a Neu 1512 2.5d on 4s, which didn't play nice on the older MM firmware. Once rolling, the MM wasn't bad, but when you are running a track and being marshalled, starting from a stop is something you have to plan for. I had to gear the MM so conservative to avoid cogging that I could not take real advantage of the torque of the Neu motor.
I have been pleased with the Quark speedo, however, I have had an issue with the case/heatsink separating from the fets/board. When using the car the board would slide inside the case and actually push the endcaps loose. It wouldn't come apart completely, but the end caps were popped loose at the end of each run. This last time was the worst where it actually knocked the top plate loose too. The FETs are no longer securely attached to the adhesive pad and heatsink. I guess now would be as good a time as any to do the adhesive mod. While I have the controller open, any reason to replace the stock capacitors or add additional ones?
