bdebde
That's All Folks!
bdebde's Avatar
02.11.2008, 04:16 PM
It is too bad the MGM doesn't give an accurate amp value, it would really be helpful. I have found with my set ups (just a guess), that the actual value may be around 1/3 of the reading you get there.
Can you gear down any and see what happens?
I know I was at my wits end with the MGM for a while, after trying 3 motors and 2 different 20c batteries, and still no difference. I was to the point where I thought that something was wrong with the controller. Finally got a Neu 25c battery and it works OK now. It is drivable now after all the messing around and finally disabling reverse, but I will likely replace it with a MMM when they come out, just because the MGM is a bit quirky.
