02.11.2008, 10:49 PM
this is the mail i've send and the reply he gave to me:
Re: MGM 16018 controller help
De : .............
Envoyé : 18 janvier 2008 13:12:39
À : david lamontagne (rcaction2004@hotmail.com)
Dear David,
I am not sure, if I correctly understand described problem - do you have this problem also with slow down mode? Please, let me know.
Can you send me monitor hardcopy with data reading from controller after LVC kick? (Via USBCOM+ and PC).
Best regards,
Grisa
----- Original Message -----
Sent: Friday, January 18, 2008 4:37 PM
Subject: MGM 16018 controller help
Hello, i've a revo convert to brushless, using a Neu 1515, 1Y motor, MGM 16018 controller and Flightpower EVO25, 5000mAh, 4s li-po pack, all on 5.5mm bullet connectors.
My problem ( and it's the problem for lot of guys who have this controller), is that the Low Voltage Cutoff kick realy too early.
I've a very good li-po pack, and i can't drain it because of the LVC how cut too fast.
When the LVC kick, i place my pack on the charger and i only put about 2500 to 2700mAh on it.(It's a 5000mAh pack!!!???!!!)
I've try to run the LVC in cutoff mode, slow down mode and nothing to do.
Just in race mode that i don't have this problem, but in race mode, it's very dengerous to kill my li-po pack, because in this mode, the LVC is disable.
In the past, i run this same truck with the same setup exept for the controlller, it was a Mamba Max and never have this trouble.
I've spend over $300.00 on the MGM 16018 and now i can't enjoy my rides.
My controller is new, i've purchase it in november 2007, and the software version of the controller is 3.11.
Need help please.
Regards!
David Lamontagne
And this is the email address of MGM:mgm@mgm-compro.cz
