6s in an hyper 8.5 pro ?
speedy
6s in an hyper 8.5 pro ? - 02.11.2008, 04:00 PM
Hi !
Is it possible to fit two maxamps 3s 8000mah packs in an hyper 8,5 pro buggy ? it's my friend who want's to do this conversion
And he like it to be a speed deamon with 2500w's of power and 60-70mph topspeeds with a mmm setup and 6s lipo
Is this doable ?
bdebde
That's All Folks!
bdebde's Avatar
02.11.2008, 04:19 PM
Those are some big packs for a buggy, I might try something a bit smaller.
speedy
02.11.2008, 04:20 PM
maybe 5000mah pack's then ?
bdebde
That's All Folks!
bdebde's Avatar
02.11.2008, 04:29 PM
That may be more doable, and should still give long run times (probably well over 30 min). Take a look at BrianG's hyper, it uses two 2s packs I believe, that may give ya some idea of how much room you will have.
02.11.2008, 04:33 PM
The 2s packs I used were 2s2p, so 4 stacked cells per side. 3s1p per side should be thinner.
But, to get the clearance for the shell with 4 stacked cells, I had to raise the body mounting a bit. If you don't mind a sloppy looking setup, you could just velcro the packs to the mudguards (I use actual trays) to gain a few mm's.
lutach
lutach's Avatar
02.11.2008, 05:18 PM
Some small capacity packs will fit the bill as well. I ran my 2 3S 2200mAh packs in a Ofna MBX with a Hacker C50-13L/BK 3695 combo. Ran for 23 minutes on grass.
MetalMan
MetalMan's Avatar
02.12.2008, 12:27 AM
Just FYI, with my Hyper 8 Pro, a 4s 4800mah 20C pack in a tray hardly clears the body.
Serum
Serum's Avatar
02.12.2008, 02:25 AM
What are the dimensions of this pack Travis?
