Not sure, what motor, batterys, etc are you planning on using. I usually aim for around 35k rpm motor speed, and 40mph vehicle speed. You are going to use the revo spur gears, correct? So you have 36, 38, 40t spurs and pinions from 25t down to whatever will fit without having part of the gear reduction assembly contacting with the motor.
