mkrusedc
NeuMaxx
mkrusedc's Avatar
02.12.2008, 11:09 PM
Do you have 3905 or 3906 model? I use 3.3 shafts without a problem on RPM arms. The problem was clearence with PowerStroke shocks not the arms.
02.12.2008, 11:34 PM
Go for the stock 3.3 driveshafts and the 3.3 knuckles. You will also need 3.3 turnbuckles. They are all good upgrades and not too pricey if you search ebay. You may need to clearance your arms slightly near the diffs as the 3.3 axles will contact the arms at each end of the suspension travel.
