Originally Posted by myndseye
Not exactly. Most motors from a given manufacturer, of the same series, but different kv ratings produce equal torque if all else is equal also. The difference comes because of the limits of the motors. For example; Mamba Max motors all have the same max rpm, lets say 60,000. To get a motor to that rpm, a certain amount of voltage would have to be applied. To find out how much voltage you need, take the rpm and divide it by the motor's rating. To get the lower kv rated motor to the same 60,000 rpm, it would take a higher voltage. With current being equal in both systems, the higher voltage system makes more watts of power, since watts are voltage * current. They both will be spinning 60,000 rpm (making neither motor faster), but the higher voltage system will have more horsepower. The higher horsepower system can pull a bigger gear, and thus go faster.
Voltage * Current = Watts
745.6 Watts = 1 HP
So really it comes down to the batteries doesn't it. The fastest is going to be the one that is most efficient on the particular batteries being used.
Or alternatively if you want to pick the the motor first, the most efficient with the highest watt input limit is the most powerful as long as the batteries and gearing are set to reach that efficiency.
