Serum
Serum's Avatar
09.02.2005, 04:26 PM
Yeah, you can sell the motor, clutch, clutchbell, carb, exhaust and tank..
You can do the measurements yourself! just measure the inside width of the the vertical plates, its 75 mm, the distance between the M3 holes of the motor are 25 mm (heart/heart)
I need to measure them too, and you use other TVP's, i am not sure if they are 100% identical to the tvp's i've got.. Please do the measurements yourself, the batterie holders only use 2 or three screws, depending if you mount them high or low.
Just do it..! ®
