Gee
A Horse's Ass
Gee's Avatar
02.15.2008, 03:02 AM
I don't know why they don't have it already. Seems easy to do. The only thing about the arrangement I posted above is that instead of a 4s pack cutting off at 12v (3.0v/cell), it will cut off at 12.7v (3.175v/cell) for a 0.7v drop silicon diode, or 12.3v (3.075v/cell) for a 0.3v drop germanium diode. Anything lower than a 4s LVC wouldn't work well since the diode voltage drop would be too great.
The nice thing about this "circuit" is that it can be contained on a small heatshrink-wrapped PCB with in/out wires (like a UBEC) and can even add a small PCB mount potentiometer to adjust the delay at which the LVC responds.
I'd try it but I don't have a test LVC to play with.
The only other way to make sure the voltage doesn't drop under quick heavy loads is to add a bunch of low-esr caps to help with the surges. It would be larger and more expensive, not to mention the initial hook-up spark due to the large capacitance you'd have to have.
I only skimmed over the technical jargen but I undestand what you are trying to do I can donate a LVC for you to try it out on. Suddenly I have one that is not being used at the moment,
Now I need to get a hold of Mike. Ten minutes before this happened I ordered the Gorilla Maxx tranny conversion and the other half of the FLM tranny case from him. I am hoping he will let me cancel that order so I can order a MGM controller and Neu motor. It doesn't look like he has many Nue's in stock though.
