Batfish
Batfish's Avatar
09.02.2005, 09:45 PM
Originally posted by coolhandcountry
What center shafts did you get there batfish?
Although I don't think Mike knows exactly where they originally came from (he had them laying around the shop for/from various projects :) ), one is a UE dogbone at 113mm (I think) and the other is an OFNA dogbone at 88mm. I'll definitely be using the 113mm and will either use the 92mm I already had or the 88mm, depending on which fits better once I have the diff mounted. Then I'll send back what I don't use and compensate him for what I keep :)
Joe
