bdebde
That's All Folks!
bdebde's Avatar
02.18.2008, 10:56 PM
That motor will turn pretty slow on 7 cell nimh. Doesn't matter which way the 3 wires go, just swap any two to reverse the direction of the motor. There won't be any resistance on the motor shaft, it will spin freely, unlike 4 pole motors that have strong magnetic resistance to turning by hand. Also, running with an external UBEC with only 7 cell nimh may cause problems depending on the UBEC you are using.
* also not a good idea to run a brushless motor with no load (not in truck) *
