superlightmaxx
superlightmaxx's Avatar
02.25.2008, 01:44 AM
RPM rims are 55g each for the Titan and 48g each for the claws! I habe both! The new LPR rims and tires from prolines are pretty light also (185g) and with 4000 4s li-po you sould be able to reach 8lbs no problem...
I run stock plastic skids, stock bulkheads and arms! only parts in aluminium I put in is the gorillamaxx chassis, shock tower and motor mount cause it didn't add any weight. I always take weight off, never addind more unless nesserary... like the cvd's but that 100g that's really worth it! lol unless you like changing your plastic driveshaft every race!
Working on:
Twin CF GorillaMaxx (8S motors on 2x2slipo)
2WD AL. GorillaMaxx (7lbs with batteries)
