rschoi_75
Certified Spaceball
rschoi_75's Avatar
02.25.2008, 05:23 PM
Thank you for that info pipeous. I wish I were racing in your area.
Sup Go-ride. My width is actually only 253mm... (sorry I have a typo in the original post). The wheels and tires I am using reduce the width significantly. The stock crt.5 buggy wheels and bowties make the width more than 20mm wider than these academy wheels and tires. Also, as far as the motor goes, yes this would be the big issue. If I am limited to only sensored motors, I may be in trouble, since I don't own any.
I was also thinking of the possibility for further mods if this idea became viable. Like an extended chassis made of 4mm thick (or thicker) carbon fiber, shorter arms from a different kit modded to fit (with cvd's from that corresponding kit), and so on....
rcm xt8
rcm xb8
rcm crt.5
