FLM xtended CVD question -
02.26.2008, 04:35 PM
Need some help here guys.
I only got 2 set screws with fabricated pins on the other half and I think those are used to replace the stampede part number 4628R on the transmission output shaft, but what type of pin do I secure between the hole in the axle and the coupling? I've got regular set screws, but wont those just spin around the axle shaft?
It's almost like I need to use the OEM pin with the FLM CVD kit and secure the axle to the coupling using the supplied set screw/pin combination except they're the wrong size...
Anyone know the proper setup for the CVD's to the tranny coupling and to the axle?
Cheers
