lutach
lutach's Avatar
02.29.2008, 02:57 PM
Originally Posted by 83gt View Post
nope. probably not a good idea. I run my MLST with one of those Wraith 7000kv motors. I have yet to find a diff solution to hold up. I can get a month or two from the MLST2 diffs, no more. This is with quark 33a procar, 7.4v 2000mAh TP Prolite, and the Wraith 7k.
I do love my MLST though. It's a whole lot of fun.
J.
I seem to have found a solution. I got some aluminum diff cases and after going throug a few viscous sets and a few 3Racing Delrin diff rings I might have actually got it right. I wanted to try the Atomic ball diff, but it souldn't fit in the diff case (Aluminum and stock). I changed the plastic diff ring with the steel one and I was so sure that was the set up, but it seems that the plastic ring gear fits the 3Racing ball diff and it is working good so far. I will eventually get the guts to grind down about 0.5-1mm from the aluminum diff case to install the Atomic diffs.
