Matthew_Armeni
Matthew_Armeni's Avatar
02.29.2008, 10:32 PM
Aren't Novak's wired a little differently? I remeber reading in their instructions for their HV Maxx controller that if you run a single pack (like a 12v or a 4s) you can't turn on the ESC when you run it, otherwise you'll burn up the ESC. You have to run an external ESC or rx pack. Never mentioned unplugging the red wire, although I'm assuming that this would work too.
  Send a message via AIM to Matthew_Armeni
