03.03.2008, 03:06 AM
A pic of your setup would be helpful.
Also are you using a ccbec or a generic bec?
Also do you have a steel spur and pinion?
Both can cause interference, make sure that your antenna wires, and signal wires are routed neatly and parallel to each other. Try to keep the batttery leads and the esc to motor wires away from the other wires. Steel gears can cause noise too. Tidy wiring seems to cure alot of glitching.
Are you using am or fm? If using am going to fm or dsm would be a good idea, and 35 bucks sounds like a steal to me!
