jhautz
jhautz's Avatar
03.08.2008, 07:00 PM
Originally Posted by pipeous View Post
was that kyosho mount a direct fit? and my 2.5d is smooth as silk with my mamba. I can drive with min throttle and crawl along no cogging, power is smooth and consistent.
The kyosho mount holes all line up, but you need to use a kyosho center diff mount in the front also. I just got the stock diff mount from the 777 and used the front upright part. The overall height of the kyosho center diff mount is slightly shorter than the stock CEN center diff mounts. You also need to make some sort of spacer on top of the diff mounts so you can tie the over the top style chassis braces to it. It takes a little custom doing, but its not to bad to make it work.
I'm not saying that the MM Neu is bad... Its just not as good as a MM with a 2 pole motor. Its totally drivable and if you didn't compare it directly you probably wouldn't think that much of it. But with a 2 pole motor it does still run noticeably smoother IMO.
to make it...
or break it...
Silent...But Deadly
