03.08.2008, 09:40 PM
I think the trouble is you're running on too low of a voltage and gearing up to compensate for the lack of speed, hence the short run times. 5s2p (if it'll fit) of A123 batteries would be much better, then you could run the smaller pinion and get about the same speed, with longer run times to boot I bet. Hopefully more opinions will follow.
