03.12.2008, 11:18 AM
Are you running the upgraded firmware with the neu too?
The 2 pole motors seem to be quiter on startup than higher pole counts. It is a totally different startup routine from the old firmware. Seems like it switches at a reasonably low rpm to different frequentcy. I will actually say that my plett max (4pole) runs smoother than my hacker motors with this revised software. Not sure why, but it seems like the mm likes the higher pole counts better, depending on gearing etc.
I have a novak 6.5 that I would like to try on 3s in my ls10. Just need to wire it up and give it a try. I was waiting on the 5mm shaft upgrade first. Just broke a c50 maxx shaft and would prefer not to do that again!
