Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.12.2008, 11:53 AM
Originally Posted by glassdoctor View Post
Now I have a question about the gears...
I have a few RCM gears and only one of them was made from a clutch bell, with the more narrow pointy teeth. The others have a tooth shape just like the other gears, such as the (soft) Century ones and Megamotor ones. They don't look much different at all.
I haven't used any of them with steel spurs yet, and would prefer to not have to. But I am curious about how they would do, and if there's a difference between the older clutch-bell gear and the ones RCM has now, which look "normal".
Our newest style hardened pinions will likely outlast the steel spur gears - they are super hard and made from premium, high wear resistant steel, then treated to super hardness. I don't want to jinx myself here, but we haven't seen a single failure or worn out pinion in well over 1000 gears sold - I have run them on the Losi steel spur for quite some time and there is barely any visible wear, if any (discoloration at the mesh point, but not wear).
That rusted pinion shown above must have been shelved for a bit to get that rusty - that is a previous version (same as Brian G's), which was heat treated for hardness as well as black oxide coated to minimize rust(black oxide is technically rust anyways) - a little oil as mentioned by others will solve this issue, but I suspect it may have been stored in a somewhat humid, musty or otherwise moist environment - steel rusts, though. Clean it, oil it and run it and you will be fine. :)
