Sammus
Sammus's Avatar
03.16.2008, 11:38 PM
Alright, maiden voyage with the sidewinder today. Damn this thing is cool! The motor (9L) stayed quite cool even after multiple top speed runs. Then esc was hot and batteries were warm (sorry no temp gun :P). I added some caps to the ESC and cut out a bonnet scoot for some airflow, and the ESC runs only just warm now. Huge improvement!
I think I might try and get some ventilation on to my batteries though, for 4000mah 20C batteries they got quite warm - although that was driving it as hard as I could (on the road, full throttle/brake bursts everywhere). Timing was set to normal and start power to low. I might have a fiddle with that and see if I can get it to improve much. Gearing is 18/46 and it has a very respectable top speed (running anacondas atm).
Initially the front wheels were unloading easily, so I went to up the oil weight an saw the thin was basically empty stock, so I half filled it with 10,000 and its a lot better now. It will wheelstand on the road but not too easily, only if you plant it. 7k probably wouldve been better if I had some. Still. This thing sure is a rocket! - I'll have to look into getting some better cells or ventilation though. Or I could just gear it down lol - will see how it goes. A few pics: Notice there is a plug hangin around there - I wanted to disable the BEC in the sidewinder, but am guess I still need to have the red wire in for programming purposes. Didn't have a servo extension, only a Y-connecter.
