Originally Posted by potreinas
I have news...
Mgm replyed to me and I made a video showing the issues I had, and they asked on saturday, yes, on weekend.
Today thanks to my video they told me the solution for my non working mgm 9032.
Now I have it working,..... BUT it doesnt work 100% ok.
I explain:
I have some issues like..
1.- I have to power up it 2 or 3 times to make it work, if not, it dont do the "beep".
2.- It only brake correctly with 2 pole motors (like feigao), with 4 pole (neu) or 6 pole ( Align 600xl) it does the Fu...ng glitchs (instant braking), and dont brake, it accelerates more!!
3.- also with 2 pole motors, as I say it work well, it glitchs a little.. just until you make full throttle and full brake, THEN and ONLY THEN... it works PERFECT, but with 4 or more poles it doesnt work :(
So...
as a 3s to 10s esc for feigao motors... WORKS (with some inconvenients)
as a 3s to 10s esc for 4 or more pole motors... you only can use it as only forward and reverse, not for braking, if you set as no braking it will work ok, but if you set some braking.. it will accelerate.
this are my progress to have a full working esc.
I'm waiting a response from mgm to know what to do. IMO It's only a SW issue that can be solved with a new version of the firmware,
as I have the 3.21 firmware, and CC-03 cable.. I can upgrade, If they give me the new firmware.
That is my problem then as I'm trying my 16024 with a Neu 1521. I like the Neu and I really don't want to put my Hacker ION-X in my truck. If they come out with a new SW that works, I'll send not only the 16024, but the 16016 as it just stopped working for some reason when I switched to Spektrum.
