luvsrc
RC-MONSTER BRUSHLESS FANATIC
luvsrc's Avatar
03.18.2008, 11:06 PM
Had that in my G2R also. Great setup. Just make sure you use some sort of heatsink on the Quark and you should be fine. If you can mount it flat to the aluminum chassis that would ork perfectly without adding any weight for the heatsink.
Fun part about that setup is if you want to see it go balistic just drop in a 6s pack and drop a tooth or 2 on the gearing and you will have more power than any truck was ever meant to have.
Will that be too much for my quark to handle it on 6 s lipo? My quark is mounted on a large heat sink . I'll tke pics next time for you guys ca see it
Brushless Jammin Truggy on NEU 1515 2.5 D on Monster mamba max with maxamps 5000mah 6s Lipo
Gorillamaxx Revo CF version on Mamba maxx ESC with NEU 1515 1Y on Maxamps 4s 8000mah Lipo
