azjc
03.19.2008, 08:02 PM
Originally Posted by Dagger Thrasher View Post
Thanks everyone. :)
MetalMan, I'll be using the smallest spur that Tamiya do for the F103GT, which is something like 90T and in 0.6 mod tooth size. I'll then have a custom-made 45T (or thereabouts) pinion to match. I'm not sure how I'll get the custom pinions made yet, but I'm hoping RW Racing will be able to hook me up there.
As for the machining...they'll be cut by a CNC 5-axis mill. At the moment I'm waiting for a quote on the parts from a company called Penta Precision, and I believe they're able to deal with the 0.5mm radius filleting that the parts have right now. If not, then I'll just have to enlarge the fillets to 1.5mm radius...but hopefully that won't be a problem.
eMachineShop is great though! It's free like Lutach said, and very easy to use. On the downside, it's kinda limited in respect to 3D parts, and will only export DXFs, but it's amazing for free. It has a few annoying bugs too...but it's good stuff. You can even directly order parts that you've designed to be made through eMachineShop themselves, though I wouldn't...their prices are astronomical...
here is a pic of a 76/40 (spur/pinion) that some guy on Ultimate Traxxas.com had on a Rustler
othello
HV basher
03.19.2008, 09:11 PM
Interesting project ... everything sounds very well pondered, but asking 4.5Kw output from a Neu 1515 sounds to optimistic. Efficiency at high Amp levels might be less then 80% requiring your battery to feed up to 5.4KW (900Watt wasted in heat) meaning 270A@20V (assuming around 3.3V per cell). Don't know if the windings of the 1.5D will hold up to 270A even for short bursts.
Which ESC do you plan to use?
