Originally Posted by Cain
...a cutoff of 3.2V - 3.3V per cell should be used. You may want to configure your cutoff accordingly.
Just be aware you might get false LVC triggers depending on the battery being used. This depends on how fast a particular LVC responds to a dip in voltage. On takeoff, the battery voltage spikes down (because current spikes up) and may dip below 3.3v pretty easily. I usually set my LVC to 3.1v give or take - good balance between cell safety and reduced LVC sensitivity.
