Thread Tools Rating: Thread Rating: 27 votes, 5.00 average. Display Modes
Trever007
03.28.2008, 08:10 PM
Hey Brian, Thanks for all your help but it doesent work lol. Here is what i have. The pack had a kokam tap on it which i switched to a hyperion tap. I wired it like you said (+on the lone black wire than the -on the other black wire reads 3.7 -on the red wire reads 7.4 on a volt meter). I pluged it in to the hyperion balancing adapter that comes with the EOS610i and it doesent recognize anything is there. Just be aware i am charging through the main leads while using the tap for balancing. Also after i get thoes to work i need to work on getting a y-balance harnes to work so i can balance both as one! Thanks Man, Trever
P.S. I want to balance them tomorrow so if its possible for you to call i will send you my number in a PM. Thanks
