lutach
lutach's Avatar
04.03.2008, 11:38 PM
Once it beeps, I push the throttle in reverse and hold it untill it starts to beep rapidly. Then I push the into the forward mode and let go. The beeping will stop after a few seconds. Then wait a sec or so and the ESC is armed and ready to go.
Ok. That seems easier. I know you can do both ways.
modellfun instructions
Jammin
Jammin's Avatar
modellfun instructions - 04.04.2008, 12:41 PM
The instructions that come with modellfun esc's are horrible, I've been trying to sink my esc with my reciver with no luck. If any one has any input please help me out. This is what I have so far, and I don't know if it's right.
1. Remote on and all settings to neutral (factory settings)?
2. Motor connected to esc and esc to reciver
3. Plug up your battery and you will hear two beeps?
4. Move throttle in to full reverse until it beeps rapidly? How long?
5. Then move the throttle to full forward. How long before you let go? Should I get any beeps before I let go, if so what kind?
6.The beeping will stop after a few seconds (which series of beeps)? Just wait a few seconds and the esc will be armed.
7. Do you need to remove the power and plug back in to operate?
If anyone else wants to give their input, please do so. You can edit the whole thing if I'm off on anything, I'm trying to get some instructions like the mamba because I don't seem to be smart enough to program these esc's with the modellfun directions.
lutach
lutach's Avatar
04.04.2008, 01:45 PM
I did the second setting on mine:
1. --no need to set up Throttle itinerary ---- startup process
pull throttle into the lowest position -- → ESC power connecting → Detect and get throttle signal one beep tone "beep" → 3 seconds delay → detected throttle lowest position → one beep tone "beep" again → can start throttle Moved.( start flying). this step total beep twice . there had light on ESC when each beep tone .
If not detected throttle signal, "beep, beep and beep ... " continued beep tones are emitted.
If the battery voltage exceeds voltage, "BEEP, BEEP, BEEP ." continued beep tones are emitted. the beep tone
pause for a bit longer,Under such circumstances, ESC refused to start motor.
2.need to set up Throttle itinerary ---- startup process
pull throttle to the highest position -- → ESC power connecting → Detect and get throttle signal one beep tone "beep" → detected maximum throttle position, "beep" tone is emitted (one beep tone) → then pull to the lowest throttle position → 3 seconds of delay → "beep" tone is emitted once, Detected the lowest throttle position → can start lifting the throttle. three beep tone is emitted .
Note : This method set up the throttle itinerary is not saved. throttle itinerary can be set up and saved permanently by our programm card.
I hope this works for everyone.
Jammin
Jammin's Avatar
04.04.2008, 01:52 PM
I'm sorry to ask you this but what is a Throttle itinerary? I'm getting the over voltage 3 beeps even with a 7.4 volt pack
Jammin
Jammin's Avatar
04.04.2008, 01:54 PM
I'm sorry to ask you this but what is a Throttle itinerary? I'm getting the over voltage 3 beeps even with a 7.4 volt pack and when I let off I get a steady two beeps.
lutach
lutach's Avatar
04.04.2008, 01:59 PM
It's another term for calibration. It's to recognize full throttle and full brake.
Anybody want one of these controllers.
Jammin
Jammin's Avatar
Anybody want one of these controllers. - 04.06.2008, 02:31 PM
Any body want a 120a modellfun esc and programmer minus the caps. 50$
GriffinRU
04.06.2008, 02:37 PM
Yes,
Send me details via PM
Jammin
Jammin's Avatar
04.06.2008, 03:11 PM
Originally Posted by GriffinRU View Post
Yes,
Your inbox is full
GriffinRU
04.06.2008, 03:23 PM
Your inbox is full
Just fixed it...
lutach
lutach's Avatar
04.06.2008, 03:32 PM
Yes,
We are going to have some fun. Artur will make that thing a beast.
04.11.2008, 12:26 PM
http://www.innov8tivedesigns.com/index.php?cPath=22_24
The search is over... well, if you concider 6s high voltage anyway.
83gt
04.11.2008, 12:34 PM
I was checking those out a couple days ago. The 120A unit looks pretty promising. I wonder what they have in the way of reverse.
GriffinRU
04.11.2008, 02:26 PM
Just received the ESC...
Well it is not as good looking as known brands, but if you guys like the way it works than we can tweak it quite easy.
Kinda odd looking with TO-220 fets, I think we can replace these fets with better ones with smaller footprint. What you think, Lutach?
And I am still waiting for the second unit to arrive from ebay.
NICE
snellemin
2 KiloWatt RACER
snellemin's Avatar
04.11.2008, 02:31 PM
AAh, better fets. Griffin is gonna work his magic.
I like the way mine works. I just don't like how hot it gets with a 7T 380c brushless 2s A123. With the 12T hacker it runs cool with 3s A123.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
