lutach
lutach's Avatar
04.04.2008, 07:49 PM
I've narrowed it down to either a kb45 8l 2200kv or a medusa research 36-60 2000kv. Now, then schulze is made for 4 and 6 pole plettys, and the timing is set up for that. The medusa is a 4 pole, and is rated for 900 watts. The kb is a 2 poler and rated well over 2000 watts. Given the schulzes combustible reputation, am I better running a lower watt load? Should I care about the pole count? Batteries will be 2x zippy 5s 5000mah in parallel for 10,000mah.
I'll be just checking in here to see how your 18.97 is doing after you start running your vehicle.
