Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
GriffinRU
04.05.2008, 12:31 PM
Griffin: So, it's not just a pure kv factor, it matters how many rotor/stator poles a given motor has as well. Hmm. I was hoping for something like "min rpm for proper ESC operation is motor kv/10", or something along those lines. I really don't feel like adding a couple more specs to each of the motors in my list.
You should be able to do that by turning the motor shaft by hand and measuring the back EMF. (Eagletree is sufficient to do this...)
And you need to check only one phase.
Count the number of zero crossings per one rotation and than the inverse of that will give you the minimum rpm. (1/# of zero crossings)
