MetalMan
MetalMan's Avatar
04.06.2008, 08:07 PM
Originally Posted by GO-RIDE.com View Post
I can't believe no one else has done this. They fit perfectly on the front if you use the body mount holes.
I was getting there . Except I am starting out with Jato shocks filled with the Traxxas oil (~35wt), and have purchased several Jato spring sets so I can find the ideal spring for my CRT.5.
Jammin X1CR front shocks do fit pretty much perfectly on the rear of the .5. Mine are set up with a good oil, but the soft springs I have on them right now seem a bit stiff. Once I mount the Jato shocks like you did I can dial in the suspension.
Nice work!
