TexasSP
Something, anything, nothing
TexasSP's Avatar
04.08.2008, 03:04 PM
No, the pede is sold now. I lost interest in it and never got any pics with the body on after I changed it.
Trimming down the front end area, down the sides, and around the wheel wells was the start. For the heat gun part you heat up the area about 1/2 inch shy of the base of the windshield and cut down the length, then using the heat gun (or hairdryer) and a block of wood or something similar, mold the body up to allow air to flow out.
Anyway, I think trimming the sides and front down some front and cutting the rear tailgate out yielded the most improvement.
I will also say that on the MM (which should be the same for the MMM) adjusting the punch control and throttle curve did a lot to help keep the front end from lifting as well.
www.cubicle101.com
