04.10.2008, 06:17 PM
raptor50, go check the CastleCreations threads, there is one called MMM sneak preview...
as for your cogging, do you have the option of changing the timing on it? if so you may need to get it up in the 25-30 degree range (or medium to high) to make it happy with the neu. Something about how slotted/ multi pole motors need higher timing.
then there is the ole' connector malfunction that will make any setup cog, and there is also the potential of it being a glitch that comes up at the highest amp moment (starting moving) you may want to try turning off the LVC for a moment to make sure your not just dropping the pack voltage too low with the higher wattage.
hope some of this might help :) hurts to drop 9 bills on a cogging setup :(
