blueb8llz
04.11.2008, 02:11 AM
Originally Posted by kingiggy262 View Post
Just to let you know the MM and the MMM will be using the same firmware v1.17 so if you are only using 3s and don't need to pull 110+ amps then the MM will work just as well on your 6 pole motor as the MMM because the firmware is not different.
im going to run on only 4s with a 7xl, but im still choosing the mmm because if i was to get the mm, i will still need the fan and the cc bec which will add up to just about 30-50 bux cheaper than a mmm. and with the mm i will sorta have to worry about heat issues esp. when summer comes around whereas with the mmm for 50bux more, i wont have to worry bout a thing. and if i ever do decide to run on 6s, i will have the option there for me.
i dunno ...this is just me i think its worth the wait. ive been wanting to go bl on my 3905 since i got the truck which is only like 2 months ago, and i almost just went with the mm, but now that the mmm is sooo close, imma waitin.
