rabosi
04.11.2008, 07:44 PM
So w/out a fan and 4s I need to set it to 14.8 as stated above correct?
The input to the bec is NOT settable. It just has to be somewhere between 5 volts and 25 volts. The output is the only thing you can set. For your receiver you can set the bec for 6v.
