If I run 2 4s batts in series, is it easier on the esc than just 1 4s
aqwut
Brushless Heavy Weight....
04.14.2008, 10:07 PM
if you up the voltage and using the same motor, it will pull more Amperes...
if you want to use lower C batteries.. run higher voltage, and get lower KV motors...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
aqwut
Visit aqwut's homepage!
Find all posts by aqwut
