04.15.2008, 12:21 AM
Originally Posted by killjoyken View Post
lincpimp: Traxxas claims 200 amps, but has anyone proved this? And can 3.5mm connectors even support 200amps?
Well sure, if maxamps packs can produce 250 amp burst specs on a 1/10mm thick al tab then a 3.5mm bullet connector should be able to handle at least 200 amps. Maybe more...
Note: all of that is sarcasm.
I go back to vacum cleaner ratings, they get those numbers the instant the motor melts, or transfers most of the parts to an alternate universe...
