harald-hans
harald-hans's Avatar
09.13.2005, 06:32 AM
Hello,
today I make a test just as I promised - configuration as known - outside temperature around 25 degrees celcius and I run my truck with a set of 14 cells IB3800 within 8 minutes - after that I took my tempgun and the temperature on the heat sink and on the motor of the HV-Maxx was around 50 degrees celcius.
The ESC is "handcold", the fan on it seems to work very efficient.
In my opinion a really good system setup !
Greetings from Germany
harald-hans
P.S. I forgot to told you that I cut out the original EMAXX-body in the area of the windshield and in the area of rear window - so the airflow seems to make the whole system work better.
