Originally Posted by SpeedAssault
Very cool
whats the speeds and gearing ?
thanks for the cam info
14/46 pinion spur with the 4.3:1 truggy diffs. Geared for around 36-38 mph on 4s. I need thicker center diff fluid as it still diffs out quite a bit even with 120k.
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 14
Total Voltage: 14.8
Motor KV: 2084
Tire Diameter (inches): 5.84
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0073
Spur/Pinion Ratio: 3.29 : 1
Total Ratio: 14.12857 : 1
Tire Circumference (inches): 18.35 inches (466.01 mm)
Total Motor Speed: 30843.2 RPM
Vehicle Speed: 37.93 mph (60.93 km/h)
Effective KV Value: 2084
KT constant: 0.65 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
