Aluminun mud guard for the mbx-5...does anyone make one? -
04.20.2008, 08:15 AM
I mounted my brake servo next to my steering servo on the mug/splash guard and I did not like the results...there is too much flex which could cause gear failure..does anyone know if another man. makes anything that would work?
Any other ideas would be much appreciated. Thanks
any idea where I could find it...thanks for the info
I found them...thanks for the heads up!
Yikes...a bit pricey, but it's worth it
Magman, i've did exactly the same thing than you on my MBX5T, i've mount the brake servo on the mudguard just next to the steering servo, and i've mount it so close to the steering servo that the gear/arm side of the brake servo can touch the carbon fiber steering servo tray.
So when i apply the brake, the brake servo don't flex/moove at all, because he touch the carbon tray.
