cmcclive
04.25.2008, 09:01 PM
Update on the modified spur gear:
It broke....
The end that the bearing goes on snapped off due tothe nylon being to thin (because I had to dremel out from the center). In order for the spur gear to be strong enough I would need to have some sort of spacer/extended diff cup so that I wouldn't need to take out so much material from the spur.
If I figure anything out, I will post.
tc3_racer_001
tc3_racer_001's Avatar
04.29.2008, 07:08 AM
it was looking promising.. :(
is there any other options for hyper spiders?
04.29.2008, 11:18 PM
just get a hardened pinion? Or harden your own by heating it to glowing and quenching in oil.
tc3_racer_001
04.29.2008, 11:42 PM
hi there paralyzed, ive got an oxy welder at school, that i could easily heat up a pinion. this would make it much more brittle though, would cooling naturally be better, just leave in in a vice or something or would oil be better... not exactly great at chemistry, i just know it becomes really brittle!!
would it be suited when using a metal spur or what?
sorry for these questions,
ryan
04.30.2008, 12:57 AM
Depending on the material the pinion is made off, the heat and quench may or may not work. I use a torch, and 10w30 motor oil. Slowly heat it up till it is red, taking care to not melt the metal. I use a metal can with the oil in it. Carefully knock the pinion into the oil, be careful it will smoke and hiss! Do not try to grab it with pliers, as this can damage the hot metal. I use a vise, or anvil to heat on, the place the can next to it and tap the pinion in with a screwdriver.
Let it cool, and do it again. The second time will help harden it further. I had success with the emaxx internal gears that I made into pinions, but they are decent steel that can be hardened. Trial and error will show if you pinion is made of decent material...
tc3_racer_001
04.30.2008, 01:02 AM
are certain brands better than others? are rrp and good? hpi? those 2 are the ones available @ my lhs... also, are mikes ones suitable to do it with? i think id just let it cool slowly, then redo it. or is it needing to be cooled quickly... thanks:)
04.30.2008, 01:16 AM
The quench in oil give it the hardness.
For the price, just get a hardened pinion from mike. They are rr pinions, and are extra hard. They work fine, and will last.
