speed demon
04.28.2008, 02:35 PM
I called mega and he said my controler probably has a built in rpm limit and with the 6pole design the controler thinks the motor is spinning at a much higher rpm then it really is. He also said that the mamba max would work fine. Should I go with MM or wait for the MMM. I only plan to run 3S but I like the fact that the MMM has a built in fan although I might be able to rig my fan up to work. descions decsions.
