Originally Posted by TDC57
MGM controller adjustment Help??
Ok gentlemen, here is what I’ve got:
• I’ve got the MGM Compro 160 amp, 24 cell brushless car / boat controller it's New!
• I'm running a Neu 1515 3d s motor
• I'm using (2) 3s Venom 5400mAH lipos
• And I’ve got it all hooked up a Spektrum 2.4GHz radio / receiver.
Here is my issue / questions .
When I power it up it will move forward (no issues)
When I go to apply brakes?? It just instantly goes in reverse??
I have no brakes what so ever.. (Hence my problem)
I do have the USBcom+ and I have the smaller CC02 that connects to my controller port.
My computer does recognize my controller as the following:
Controller Name -16024-3Cars
Controller Version 3.14
Last Change 11/01.08
Trottle Min is @ 1.107
Neutral is not highlted?
Throttle max is @ 1.898
Number of poles is set @ 4
Now for the Usser settings! (for what it's worth)
Type of model (car) <=I=>
Brake / deceleration is @ medium 1/0,39s
Acceleration is @ 0.65s
Timing is set at automat
Behavior when battery voltage is down is set @ reduce speeds
Battery type is set @ 6Li-pol
Range of the neutral zone is set @ 12%
Automatic correction of the neutral is set @ no
Freewheel in set @ no
Auto brake in neutral is set @ no
What have I done wrong?? are what should I be doing??..
Again the forward works great! No brakes just reverse
Thanks so much for your time!!
Shaun.
Shaun, Try setting freewheel to yes
