lutach
lutach's Avatar
04.29.2008, 01:29 PM
Originally Posted by 83gt View Post
The idea behind undergearing generating more heat in the motor is that the motor is running near max RPM all the time since you'd be on full throttle more to get the speed you need with lower gearing. You can tell best if you feel you are on full throttle most of the time. If not, then gearing up probably will not make much difference. If it were me, I would get both a 13 and 15, so i could try them both.
J.
That's what I would do. I don't think 158F is that high though.
